There does not appear to be any way to set the time on the BV8. It does display the correct time when you view the programme guide, so I assume it is simply getting the time from the digital terrestrial tuner. The only time settings I can find in the menus relate to time zone, daylight savings, and the play and sleep timers – no way to actually set the time manually.
