Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3500 and Beocenter 8500 – possible? › Reply To: Beolab 3500 and Beocenter 8500 – possible?
18 June 2024 at 12:04
#56566
GOLD Member
I just ran your proposed setup through the B&O Product Configuration Guide and it stated that either BL1611 or 1614 is suitable. There was a note to say that the TV ‘must be equipped with software Build 109b or higher, in order to be compatible with the Beolink converter’, but you’ve already tested it with the BL1611 so I doubt that you will have any problems.
I wonder what that comptability issue is about, or if it is just about the 1614 Beolink Converters missing voltage for the Masterlink network. New rabbit hole to dive into 😉
