Madskp
GOLD Member
I run a powerlink cable from my Beosound 9000 into a Almando that is connected to my Beolab 5’s. I can control the Beosound 9000 fully with my BeoRemote One BT (which controls all my other units).
Could you elaborate a little on how this works, Is it just the IR function from the BeoRemote one you use for this control or is it something in the Almando box (which of their products is it?) that can recieve the Bluetooth signals from the Beoremote One and relay them via the data in the powerlink cable?
Thanks in advance
