Home › Forums › Product Discussion & Questions › BeoLab › Beolab 3500 and Beocenter 8500 – possible? › Reply To: Beolab 3500 and Beocenter 8500 – possible?
10 June 2024 at 15:37
#56414
Great that the equipment is working.
When you are going to choose which BL3500 to keep you might consider if they are MK1 or MK2, and also which software version they have. All versions should work with your current setup, but judging from your posts you might have caught the Beovirus (like many of us 😉 ) and may want they most future proof version.
Software version on BL3500 can be checked by pressing Menu + 0 + 0 + GO on a BEO4. If the BL3500 is a MK2 you have to press Menu twice in that sequence
