Home › Forums › General Discussion & Questions › BEOTOOTH 5500 : A Datalink Bluetooth Receiver › Reply To: BEOTOOTH 5500 : A Datalink Bluetooth Receiver
10 June 2024 at 04:46
#56394
Hi @pilatomic,
I’ve been enjoying my Beotooth for a little while now and have some minor feedback.
- I can’t “steal” the audio connection using another device while the first device is still connected. I have to disconnect the first device before the second device will connect. Would be a nice feature to have.
- If I power off the Bluetooth while my PC is connected, then enable BT again, it will connect to the Beotooth but not show an audio device. I have to press the pair button on the Beotooth and reconnect to get an audio device to show in Windows 11. Might be a Win11 problem, but it’s pretty consistent.
- The volume range seems to be non-exponential. The bottom half of the range doesn’t seem to change the volume much and the audio cuts out completely at about 1/10 and below. This is with an iPhone, by the way.
Not a big problem, but thought I’d just mention it.
