Home › Forums › Product Discussion & Questions › BeoMaster › BeoMaster 3500 mute with Beogram 3500 query › Reply To: BeoMaster 3500 mute with Beogram 3500 query
21 April 2024 at 20:50
#54322
this is correct behaviour. Allows the BM3500 to distribute the sound toothed rooms if you are running a link system.
If you press STOP you will achieve what you are describing.
