Home › Forums › General Discussion & Questions › ml powerbox alternative › Reply To: ml powerbox alternative
And to be complete, even the fully wired PowerLink cable might not be enough to get it working ? https://beoworld.org/forums/topic/beoplay-connection-hub-beolink-passive/
Yes that’s right. This might also be an issue with the BLC
My latest plan is to use a BLC (I do have a ‘JOIN’ IR eye already) and two BL7-4s (that I now have as well). I will see to feed the L/R speakers with Left and Right signals only. I took the BL2000 to the garage for a ‘fit’ and I fear it will be a bit small in the 3x6m space. And now I have a purpose for those 7-4s!
Talking about an upgrade 🙂 But this will avoid those extra boxes for sure (unless you count the 7-4s as boxes).
The BL2000 will move to the garden I reckon (cabled).
Or you could get an extra BLC now that you have the powerbox 😉
