Home › Forums › General Discussion & Questions › ml powerbox alternative › Reply To: ml powerbox alternative
6 April 2024 at 10:21
#54120
I have now tried to a 1611 converter to the setup, so both the BLC NL/ML, BLC 1611 and BL3500.
Now the BL3500 says ML OK
The voltage on the Pink wire power + is 10.9V
The voltage on the blue vire power – is -10.9V
The voltage on the Green wire data + is 0.25V
The voltage on the green/white wire data – is -0.25V
So it seems that the BLC NL/ML does not have enough power to pull the voltages to the correct levels when a piece of ML equipment is connected.
So it might be that the options are:
- The ML power box
- A BLC 1611
- B3OHACK3R’s solution
- or a real ML audiomaster
