Madskp
GOLD Member
Could it be the BLC only fails to supply the POWER+
According to my measurements it does supply that.
What I noticed when I tried measuring again is that power + and – starts at a low voltage 3-5V when the BLC is booting, but then changes to the +10,8V and -10.8V when it is ready.
One thing I did not mention before is the blue/white wire for ML sense. That has no voltage, but should not be relevant to the BL2000. Also in the RJ45 ML cables it is connected to power+
If I can find the time in the weekend I will try to connect a BL3500 to see if I can make it do anything
