Home › Forums › Product Discussion & Questions › BeoLab › beolab 4000 smal humming sound when idle. › Reply To: beolab 4000 smal humming sound when idle.
		22 March 2024 at 10:50
		#53704
	Some noise is normal.
Especially for speakers with class A/B amplifiers.
If the power LED on your speakers are also a power switch then they got class A/B amps. If the LED is LED only (not a switch you can push) they got IcePower digital amps.
If you can hear the noise within 1 meter distance but not let’s say 2 meters away it’s what I would define as normal.
