Home › Forums › Product Discussion & Questions › BeoSound › Theatre › Beosound theatre for listening stereo music › Reply To: Beosound theatre for listening stereo music
not sure what speaker group / listening position you are using for music? And what sound mode?
If you using sound mode = Music, then if your input signal is stereo (2.0), then the Music sound mode already is set to Direct – i.e it will just play from 2 of the Theatre drivers.
If you have been doing the above, all that is left to do then is to listen to music with True Image on, and then play around with the various front / back, left /right, height settings until you find something you perhaps prefer.
personally, I wouldn’t bother – there’s only so much you can really do if you want to not twist the image too much, and stay somewhat true to the recording.
