Home › Forums › General Discussion & Questions › How to wire 7 din plug to Beogram › Reply To: How to wire 7 din plug to Beogram
14 March 2024 at 14:22
#53420
Thanks for that Keith. I appreciate it.
the yellow wire in that image of the 7 pin plug is going to #1 pin. I thought it should be #7 pin…
The photos are helpful but I can’t see which pins the coloured wires are connecting to. Also the silver wire I can only assume is the ground wire, which I thought was the main black one (there are 2 black wires, one thinner than all the rest.
im so confused, starting to wish I’d never bought this, but I did t k owned but the din plug off…
thank you though
