Home › Forums › Product Discussion & Questions › BeoLab › Finally got beolab 8s set up . › Reply To: Finally got beolab 8s set up .
11 March 2024 at 11:07
#53301
GOLD Member
Maybe 8s as front and 8000 as rear will perform better in the surround system , 80% sound come from L C R,and 8s is technically better than 8000
I’d second that…..didn’t you think of that?
I guess that would also be a better solution optically, since the setup is pretty squeezed in the front due to the placement.
Only reason not to do so, could be that you’d have to have a PL cable running to the back.
That might be doable, though (?)
Otherweise you could use a Receiver 1 for WiSA connection to the BL8000 in the back.
