Home › Forums › Product Discussion & Questions › BeoCenter › Beocenter 2 buying considerations › Reply To: Beocenter 2 buying considerations
t is one of the most tempting and beautiful B&O systems imho. The metal surface and the sliding wing mechanism are only two out of a lot of nice features.
Yes it is a very nice system indeed, with some of the B&O magic 🙂
Could you explain, how you plan to approach this, please? Mine is in a very good technical condition, cosmetically the soft touch on both units is starting to get sticky.
I am using Isapropyl alcohol and toilet paper. Had to rub the spot three times to get this result which I think is far better looking than the dusty, scratchy and sticky surface.
It takes some time and rubbing, but I think it is worth it.
You might wan’t to start on the back to see if you like the surface underneath.
If you know how to take of the wings it might be worth doing that to eliminate black spots on them when doing the edges.
P. S.: To my knowledge, the head unit is always capable of playing CDs and DVDs. The socket unit makes the difference, although it seems that not many of the “Audio only” units are available. If the Scart plug is provided (I guess Europe version only), your version is able of playing DVDs.
Yes mine is playing DVD’s, but for the short test I did the controls did not seem that responsible and the interface was horrible looking. Well it’s a long time since I used a DVD player, so might just have gotten to used to streaming movies.
I might Hook it up to my BC6 as a DVD player just because the functionality is there, but guess I’am not gonna use it much for other than testing purposes.
