Reply To: Beogram 4002 lifts in middle of record
Home Forums Product Discussion & Questions BeoGram Beogram 4002 lifts in middle of record Reply To: Beogram 4002 lifts in middle of record
#51680
auric
    • Topics Started 14
    • Total Posts 83
    So here’s my guess.
    The tone arm is mounted on sled that is driven by long threaded rod.
    Unlike the 8000 series turntables, the threaded rod is not fixed on both ends and so can become mis-aligned.
    The rod is held in place only on the right end of where it is terminated by a bracket and pulley (where the sled motor is). If the bracket has come loose and the rod is misaligned then what happens it the sled can only go partially across the record.
    The sled rides across a fixed polished rod. The fixed rod and the threaded rod needs to be reasonably parallel across to each other. If not at some point the divergence between the two becomes to great and so the sled can no longer move.
