Home Forums Product Discussion & Questions BeoGram TX2 Bulb and Sensor Locations Reply To: TX2 Bulb and Sensor Locations
#51401
clamping
Ha, answered my own question. Facing the front of the turntable, it’s on the left side of the carriage under another (1 screw) cover. You have to drop the tonearm support, then the little tan pcb where both the sensor and bulb are mounted slides out of its little slot, I just wedged it gently with a flat head eyeglass screw.
