Home Forums Product Discussion & Questions BeoLab Beomaster 3500 and Beolab 7.1 connection. Reply To: Beomaster 3500 and Beolab 7.1 connection.
#51263
Yes, you can add the Beolab 7-1 via Powerlink as an extra spkeaer, although you will only get stereo sound through all speakers, not surround sound.  You need a Powerlink mk.3 cable like this one (this can connect to any spare socket under one of the 6000 speakers):-
https://soundsheavenly.com/powerlink-8-pin-din-connection/20-266-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/1-length-05m
Kind regards, Steve.
