Home › Forums › Product Discussion & Questions › BeoLab › Setup BeoLab 2000 to get audio from Beolink 1611 converter › Reply To: Setup BeoLab 2000 to get audio from Beolink 1611 converter
#51161
Madskp
GOLD Member
If it was working before the building works I woulds suspect the Masterlink cable connection. The only setup of the BL2000 in a masterlink system is an option setting which should be intact even when unpowered.
However you can try setting it by pressing List + standby at the same time. Then press list until option shows in the BEO4 display. The press go and list again until it shows L.OPT. Then press 6 and go.
The speaker should now be set to option 6 which is a link room that can respond to both audio and video commands.
By the way whicjh command do you use to activate the working speaker?
The service code you are mentioning should only be nessecary If you are connectiong an audio device directly to the Masterlink connector on the speaker without the use of the 1611 converter
