Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8 arrived… › Reply To: Beolab 8 arrived…
10 March 2024 at 18:39
#50601
Thanks for confirming .
to be honest , the fact they can stream Bluetooth quick and easily when everything is turned off is a MAJOR plus that I will rarely use , but I suspect it will be used often by others .
the sounds they produce is more than acceptable as is .
