Home Forums Product Discussion & Questions BeoLab Beolab 8 arrived… Reply To: Beolab 8 arrived…
#50600
Millemissen
    but now I have a question :
    I’ve been through eclipse settings , and beolab settings on app , and can find no setting for using the 19 sub with the 8s for music streaming .
    is it possible to do this ?
    or will the sub only turn on when the tv is on , and the 8s will only stream Bluetooth when tv is off ?
    You can not add a sub to the BL8’s.
    Only way is to make a Speaker Group with the BL8’s and the BL19 in the BV Eclipse – which means that the BV Eclipse will turn on for processing the sound.
    You can not use the BL8’s for BT, when set up with the BL19 as a Speaker Group.
    As far as I remember you can stream via BT to the BV Eclipse directly and this way use the BL8/19 Speaker Group for listening.
