Home › Forums › Product Discussion & Questions › BeoLab › Beolab 8 review video › Reply To: Beolab 8 review video
#49950
syrianos82
Question about this suggestion:
Set the external loudspeakers to Left- and Right-Front
Set the centre output on the television to Centre Front
Set the Left and Right internal outputs of the television to Left- and Right-Surround
when calibrating the theatre with multiple speakers some speaker roles (and I believe woofers) are left out. Does the theatre still use these woofers for other channels or not?
The side firing are left out most.
I could imagine the sides supporting a surround or even back speaker roll and keep the BL28 behind the sofa as surrounds for most effect/usage.
With the added BL8’s should the L and R woofer group of 3 be left as L/R  channels with added 8’s further out in line with BST or all configured as centre?
BST gives a master control and balanced calibration but the assignment ment of channels is a bit unclear when having built in and external speakers competing the same position they are built for
regards
