Home › Forums › Product Discussion & Questions › BeoSound › BeoSound 5 won’t startup anymore › Reply To: BeoSound 5 won’t startup anymore
Hello, I missed to comment on that previously.
I notice the same problems on my BS5 after change to a new HDD (a SSD). The system works in principle after a cold startup (when power switched off in between). It is also ok when accessing the system frequently. It fails with the same description like done by Luc if there was much time between the access to BS5.
I think it is not a problem of the motherboard but of the Hibernation of the OS (Win XP embedded). I have to add that startup did also fail sometimes if a USB device is added (again an OS related problem). I read somewhere that this (USB attached) is not foreseen…
Best regards
