Home › Forums › BeoWorld around the world! › Dutch › Connect Dual pick up with USB to Beocenter 9500 › Reply To: Connect Dual pick up with USB to Beocenter 9500
8 September 2023 at 17:13
#48820
Thank you, Yann. It is that connection but it also has a USB connector. Can I use that as well?
I did not mention USB because, as Trackbeo stated, USB is meant for connexion to a PC in order to digitize LPs.
The best (and economical) solution is the analog way.
According to the switch position, you can connect the Dual to the phono input (Phono position) or Aux / Tape 2 inputs (Line position).
Yann.
