Home Forums Product Discussion & Questions BeoGram Connecting Beogram RX2 to BeoMaster 1900 Reply To: Connecting Beogram RX2 to BeoMaster 1900
#48680
BeoworldGarcia
The new rep-amp is working much better. But right channel is not working, think it may be the cable.
So for B&O MMC2 you need an MM compatible pre-amp, like the one I bought:
And the reason I even need a pre-amp is probably because the BeoMater 1900 I have has screwed up Phono Inputs as was said above.
Thanks all.
