Home › Forums › Product Discussion & Questions › BeoLab › BeoVision 4-103/BeoLab 10 problem › Reply To: BeoVision 4-103/BeoLab 10 problem
I have exactly the same problem. Happened just yesterday (19th Feb 2024). When this happened once previously I told the BL10 off the wall mounting and noted that the LED at the connection socket (where the Powerlink Cable and Mains Power plug into) was orange. This indicates the thermal protection circuit had kicked it. I simply powered off for 5 minutes and powered back on, all worked fine. This is what the service manual recommends.
This time however the LED remains RED i.e. in standby mode and not switching on.
Apparently there is an F1 Fuse that is the next step to check if this is blown. I am reluctant to play around with it myself, so will need to get in touch with a B&O Service Tech (few and far between in Melbourne Australia
