Home Forums Product Discussion & Questions BeoSound Using Core for TV Sound Reply To: Using Core for TV Sound
#48090
trackbeo
Also avoid the temptation to use a TOSlink->3.5mm optical adapter with a standard TOSlink cable.  The data stream depends on the distance & tolerance of the gap in this friction-fit connector.  Too little light output or too much reflection at the junction, and you lose!
TOSlink-3.5mm-adapter
