Home › Forums › Product Discussion & Questions › BeoSound › Beosound 5 repair › Reply To: Beosound 5 repair
29 July 2023 at 19:05
#47951
Hello,
you said, reset the CMOS, did you check whether the battery has the correct 3V voltage?
I had one where I thought as well the mainboard might be dead but it was just an old battery
In case of mainboard, it might be interesting whether similar VIA EPIA mainboards could be used as well. meanwhile they got more and more expensive
Best regards
