Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 5000 power problem › Reply To: Beomaster 5000 power problem
22 July 2023 at 08:56
#47590
Have you double checked the connections to the processor board (one by one) at the front of the unit. If it is actually turning on (which is a good sign, didn’t fry the CPU ) it may be a connection issue seeing as the cables and corresponding plugs are pushing 40 years old. Additionally, you may want to look at the internal IR sensor. They can cause a host of unusual problems when they start to go bad.
