Home › Forums › Product Discussion & Questions › BeoSound › Beosound Core + IR eye + Beoremote One › Reply To: Beosound Core + IR eye + Beoremote One
20 June 2023 at 20:28
#47260
The BROne/IR works like the Beo4 with navi.
This means that you will have to set the remote version used to ‘navi’ in the menu of the BV7.
However, depending on the sw version older versions of the BV7 does not support the Beo4/navi.
Please have a look in the settings….should look like this:
