Home Forums Product Discussion & Questions BeoSound BeoSound 5 no network connection Reply To: BeoSound 5 no network connection
#47061
Alan
—SOLVED—
got some advice from B&O customer support: clear the databases from the maintenance menu, if no cd ripper is installed. Which I did, as I do not have any ripper attached. Rebooted and it took a some 15 minutes and the new n.radio database was downloaded, shows as such in the Product Info and all works fine.
(If there is a cd ripper installed, you need to manually delete the n.radio database out from the service menu ( E:\cache\data\nradio.db) and that triggers a download of the latest database.)
Of course, this only works if you have connection to the internet and you need to make sure that the connectivity is established.
