Home Forums Product Discussion & Questions BeoVox speaker stand suitability s45-2 vs mc120.2 Reply To: speaker stand suitability s45-2 vs mc120.2
#46751
Dillen
GOLD Member
    Apparently, the height matters to some extent – or Bang & Olufsen wouldn’t have made different stands.
    Your speakers will play regardless – of course – though it may not be at the most ideal height, which is usually centered vertically around the height of your ears when listening (usually in a sitting position).
    Also, – the S45-2 stands came in two versions; One has the vertical part assembled with a screw from below to the base part, the other is permanently welded.
    I think the version with screw wouldn’t be strong enough for MC120.2 to be safe.
