Home Forums Product Discussion & Questions BeoCenter Beocenter 2200 Reply To: Beocenter 2200
#45940
Dillen
    What parts are not available?
    Check if the motor bushing touches the metal bracket.
    If it does – replace the motor mounts.
    https://www.beoparts-shop.com/product/motor-suspension-rubber-bushing-grommet-f-several-beogram-beocenter-models-2/
    If the motor itself is noisy, it must be taken apart and repaired (most can be)
    – or replaced, and a good condition used original motor would be the way forward in that case.
