Home Forums Product Discussion & Questions BeoCord Beocord 8000 BP534 transistor Reply To: Beocord 8000 BP534 transistor
#44480
Pindsen
    Hi again,
    It turned out that the BC8000 did not have a “TR9” issue – my issue was also a little different. It could Play, REW and stop by command but when selecting FF it stayed in FF eventhough pushing Stop. Measuring around on board 4 showed correct electrical signals. It turned out that the FF solenoide was half stuck staying in outer position. Lubricating the rod inside solved the issue.
    Finally everything works 🙂
    /Pindsen
