Reply To: BeoGram 6000 chassis suspension
#4325
Vinlyfrontier57
    Thanks again Mark-sf.  I just got back from hols and measured my drive belt using the method you suggested.  It is 560mm long.  I think your figure of 88mm must be for a different belt?  But thanks for the link to Beoparts-shop – this is a really useful, as they also sell the drive belt for the carriage servo motor, which I need.
    Martin – thanks for the reminder about the carriage screws.  I think these are fully withdrawn but will check again!
