Home Forums Product Discussion & Questions BeoLab BeoLink Converter 1611 Innovative Configurations Reply To: BeoLink Converter 1611 Innovative Configurations
#42550
Madskp
GOLD Member
    • Denmark
    Just a quick update to this thread. I recently bought a NL/ML converter and today I had half an hour to play a little arround with it. So I set it up as ML source center, and  made integration with my Beoplay V1 on the NL side, and connected the  Beolink converter 1611, MCL2AV and my Beocord 3500 on the ML/datalink side:
    Beoplay V1 – NL – BLC NL/ML – ML- BLC 1611 – datalink -MCL2AV – datalink – BC3500
    I setup the Beoplay V1 to use A.MEM for the A. MEM on the BLC NL/ML, and what do you know. Full control of the BC3500 from my Beoplay V1 in another room.
    There might be many detail I have overlooked in my short testing, but generally it seems to work through the whole chain.
    I will of course make some more extensive experiments, but I will put that in a separate thread as it might be more focused about the settings in the BLC NL/ML
