Home Forums Product Discussion & Questions BeoGram BEOGRAM 1000 motor gets hot Reply To: BEOGRAM 1000 motor gets hot
#42020
chartz
GOLD Member
    Hi Roger,
    It does get hot but not burning hot. Are you sure it runs smoothly (lubrication) and that you have the correct speed right away? Did you have to increase pitch adjustment to its end stop? Do you have the original belt?
