Home Forums Product Discussion & Questions BeoGram Beogram4000 behaving erratically Reply To: Beogram4000 behaving erratically
#39650
hcraig244
    Couple of things here….firstly take out OTR4 and check it, if this is good you need to look at the power limiting part of the circuit….the set of contacts (those leaf spring contacts again) that need to be closed, thus shorting 7R1 to ground,  when the solenoid is initially activated allowing max current to pull in the solenoid coil before opening up when the armature moves to drop the tone arm…..its possible you dont have a good connection at these contacts..
    Craig
