Home Forums Product Discussion & Questions BeoCord Beocord 7000 voltage issues Reply To: Beocord 7000 voltage issues
#38680
alf
SILVER Member
    As another check I disconnected P2 and P3, which are the supply lines to the deck.
    so I must ask again:
    what makes the transformer secondary AV voltages almost “evaporate” when
    that transformer is connected to board 3 where its AC voltages are getting
    rectified to DC ?  Which load exactly is there ?
    just like to understand – thank you
    ALF
