Home Forums Product Discussion & Questions BeoSound Theatre New product launch – beosound theatre? Reply To: New product launch – beosound theatre?
#38260
Millemissen
    The system works fine but I can’t integrate it with my link NL/ML system. Have heard that a sw update should allow for that.
    You will not be able to ‘integrate’ it with other NL devices.
    What you mean is probably to ‘connect’ it to…
    ……in order to start a source directly from the BST.
    This – sadly – is not yet possible (how long will it take ?)
    But you can ‘expand’ from another device – this is what I do when I listen to CD’s from the 6500 system->NL/NL Converter.
    I start playback manually and can then listen on the BST.
    54B4842E-80FC-4A58-8C48-35CF771C1BFB
