Home Forums Product Discussion & Questions BeoSound Theatre New product launch – beosound theatre? Reply To: New product launch – beosound theatre?
#38190
FrankieFrank88
I’m on the beta firmware a few days atm. So far i’m not really liking it. The beta firmware makes my tv loose the CEC connection once in a while and overall a lot more HDMI handshake problems…
Also but this only happened once. The soundbar deactivated all my speakers which are connected through powerlink and only used the center channel of the theatre. A reboot of the soundbar solved it. Again it happened during HDMI sync issues. I’ve reported these problems both through the app. The latest official release didn’t have any of these problems.
The good is the sound level issue if you use the soundbar as a complete center speaker has been solved and the speaker roles can be adjusted to none if you want to play around with presets.
