Home › Forums › Product Discussion & Questions › BeoLab › A question on circuit board from my beolab 6000 › Reply To: A question on circuit board from my beolab 6000
5 August 2022 at 12:20
#36640
You’d have to remove both the bridges (i.e below each 120V label) and replace across the 240V. If you consider that the transformer winding terminals are numbered 1 to 8 from the left, then for a 240V supply you need 1 to be connected to 5 (hence the bridge), with the input supply connected to 4 and 8. (That’s from the service manual – avail to Silver and Gold Members!)
Thanks for your advice and the silver/gold material!
Is it really just as simple as that to change the voltage input?
Thanks!
