Home Forums Product Discussion & Questions BeoLab BeoLab 14 – HELP Reply To: BeoLab 14 – HELP
#35673
Millemissen
    A few comments…
    The BL14 system is an active (means that the ampflication is built in) loudspeaker set.
    It is meant to be used with an audio device that has pre-outs or the normal speaker outputs.
    That is what the adapter is meant for.
    You should be able to get this still – maybe on the used market (?).
    6193099E-4873-4F06-AAD2-B6EA4D3A0AEA
    The RJ45-Powerlink connections are for connecting to a Beovision as the source (which is a tv with audio processing and pre-outs built in).
    P.S.
    My best advice would be to contact Steve@SoundsHeavenly for further advice.
    You can find a link at the bottom of this site (he is a sponsor of Beoworld).
    P.P.S
    You can find more about the BL14 on the old forum – e.g. here:
    https://archivedforum2.beoworld.org/search/SearchResults.aspx?q=Beolab+14&o=Relevance
