Home › Forums › Product Discussion & Questions › BeoMaster › BeoMaster 7000 to BS Core › Reply To: BeoMaster 7000 to BS Core
28 May 2022 at 19:25
#35078
Hi Everyone Thanks for the advice. MM, the Aux/TV port is unfortunately an input.
Are you sure/did you try it?
That port used to be the connection to a compatiple BV ..….and this works both ways.
P.S.
It is very long ago that I used it this way ?
