Home › Forums › Product Discussion & Questions › BeoVision › No Bluetooth on Beovision Avant 75 › Reply To: No Bluetooth on Beovision Avant 75
28 May 2022 at 19:25
#35063
Since you write about ‘a changed mainboard’, I assume that you have a MK1 version. In that case it is very easy to answer – altough you might not be pleased – there is no bluetooth support whatsoever on that tv! MM
Thanks for your reply.
If the tv doesn’t support Bluetooth why does the instruction manual refer to how it is used etc?
