Home › Forums › Product Discussion & Questions › BeoGram › Playing a Beogram 5005 via 7 pin female to RCA › Reply To: Playing a Beogram 5005 via 7 pin female to RCA
Hi Cavscout,
Thanks for your enquiry. If your amplifier has a built in phono pre-amp, then you just need this cable to connect it to the phono input of the amplifier:-
If the amplifier doesnโt have a pre-amp, you will need this pre-amp kit instead, which comes with all cables needed and full instructions, ready to โplug and playโ:-
https://soundsheavenly.com/beogram-record-players/12-2196-pre-amp-bundle-for-bo-beogram-and-all-turntables.html#/36-output-5_pin_din_aux/41-power_supply-uk โ please choose the โTwin RCA plugsโ output option for your amplifier.
If you are unsure about whether the amplifier has a built-in pre-amp, please email me the full model number and I will be pleased to confirm this.
Kind regards, Steve from Sounds Heavenly.
