Home › Forums › General Discussion & Questions › B&O Loudspeaker Switch IR Eye pinout help requested › Reply To: B&O Loudspeaker Switch IR Eye pinout help requested
15 May 2022 at 10:57
#34823
I made some notes when I used an MCL sensor as a Beolink PC IR sensor. The three connections that you require are: Ground – Brown IR Data – Yellow +5v –
Hi Guy, does that mean you can use MCL IR sensors (square ones) with more modern hardware that need round sensors ?
To be more precise, would an MCL82 type 2041 sensor be able to control a beolink passive ?
Thank you.
