Home Forums Product Discussion & Questions BeoGram Beogram 1202 Reply To: Beogram 1202
#34710
Mark-sf
In the bottom cover there are two holes that adjust the set down point for 7” and 12” records. It is easiest to place it on a stand or supports so that you can watch the arm without having to constantly flip it. If your bottom does not have the holes then you will need to remove the 4 corner screws and remove it first. These eccentrics should be marked and are in the from of the cam gear.
