Home › Forums › Product Discussion & Questions › BeoVision › Limited HDMI bandwidth on Eclipse Sound Center 1st Gen ? › Reply To: Limited HDMI bandwidth on Eclipse Sound Center 1st Gen ?
I set ATV to Dolby Vision/60.
played a video on the YouTube app that was supposed to be DV 60.
This is what the stats liked like:
Thanks again for checking.
And yes – it does make sense.
I don’t think that it was displayed in DV or HDR. If you look at the Codecs line it should have been 9.2.
I played a DV-video in the webos youtube app and the panel on the TV shifted to HDR-mode.
Maybe it will work if you force the ATV to HDR/60.
For youtube videos I will be using the webos app in the tv in the future since it can display HDR/60 videos.
The problem is with apps like Disney+ and ATV+ since they are not available on Eclipse 1st gen. They are available on the normal LG C7. I have been in contact with B&O about the missing apps. They are aware, but suggest to buy an ATV and use the apps there ..
Best Regards
Dyssegaard
