Home Forums Product Discussion & Questions BeoCenter how to select DVI on Beovision 6-22 Reply To: how to select DVI on Beovision 6-22
#34477
matador
I have Beocenter 6-26 so it may be work differently.
AV3 is set to an input selectable with an hard key (V.MEM maybe, can’t say because I use a blind Beo6 now, sorry…). Then the HDTV option below is set to DVI.
I remember that even when I was using a Beo4 It didn’t never required to use the LIST key.
I even remember it was an AV Beo4 because I used that key to start the BV as a speaker with the picture muted.
Hope this helps.
