Home › Forums › Product Discussion & Questions › BeoLab › A question for Geoff Martin on BL8000 Damping… › Reply To: A question for Geoff Martin on BL8000 Damping…
25 May 2022 at 20:05
#34350
There are 2 different types used. A 6mm and a 19mm wide foam-tape. I use the original foam-tape used by B&O to keep the BL8000 as original as possible.
Could you tell us where you get it, and what’s the thickness for the two strips?
Thank you.
